does anybody know what this bolt is for?
RE: does anybody know what this bolt is for?
ORIGINAL: 157db
NO, its a one time use fastener and removing it or untorquing it
to get a wire under it would require it to be replaced. I would not
recommend using suspension mounting hardware for an Amp ground.
ORIGINAL: pascal
I think it's the linkage that's connected to the top of thepumpkin rear axle housing.
Not sure what it's called...
ORIGINAL: 157db
ORIGINAL: surfbum7190
looks like a good grounding bolt. ground your cb in there HAHA
Try and get 129 Ft Lbs of torque on a fastener with a ground lug
under it. It will mash that lug to pieces before the 129Lbs is reached.
Or wont hold 129 Ft Lbs after the soft copper groundlug crushes in the future.
ORIGINAL: moosestang
1 time or 2. I bet you $19,999 that 99.999999999% of people with an aftermarket upper control arm, did not replace that bolt.
ORIGINAL: 157db
And that makes it correct?
Ford would beg to differ.
I was just passing on the correct info as the workshop manual states.
But its probably just for insurance purposes.
So call me out as being wrong once again.
Just a lot of wrong info in my posts.
Skip over any post by 157db.
Its all a bunch of unnessasary **** retentiveness.
157db is of his rocker and having a kiniption fit.
ORIGINAL: sailing220
It looks much too far forward to be that. It is definately for the UCA.
ORIGINAL: pascal
I was right.
I took that picture today.
For the others :This bolt is one of three that holds that upperfloating arm on therear housing.
Twoof them fasten from the bottom and the first one, from the inside of the car.
See pic.
[IMG]local://upfiles/78700/F50FF91439DB4BB9B8B91B2D5C007237.jpg[/IMG]
maestro1024
09-21-2015 02:40 PM
trashxtrash
09-20-2015 10:49 PM
