Exhaust question (leaks)
Old Apr 28, 2008 | 09:28 PM
Riptide's Avatar
Riptide
Default Exhaust question (leaks)
When are leaks typically apparent and what do they sound like? Do you hear it on acceleration, idle, or deceleration? Or both?
My boomtubes sound great but I've noticed when the car decelerates and it's in gear I can hear a kind of rumbly noise that isn't really that smooth. Not sure if it's abnormal or not.
Old Apr 28, 2008 | 09:31 PM
surfbum7190's Avatar
surfbum7190
Default RE: Exhaust question (leaks)
just get under your car and have someone rev it for you. check all the bolts with your hand. dont touch it though cause its hot. my h pipe was leaking a little so i just welded it on
Old Apr 28, 2008 | 09:52 PM
onederful100's Avatar
onederful100
you can try putting some soapy water on the connection and if it bubbles theres a leak.
but if you're talking about popping or rough gurgling sound w/ decceleration, that would be normal w/ any straight thru muffler delete and nothing to worry about.
Old Apr 28, 2008 | 09:56 PM
surfbum7190
ORIGINAL: onederful100
+1 soapy water is a nifty idea
Old Apr 28, 2008 | 11:07 PM
Riptide's Avatar
Riptide
Yeah it's kind of a gurgling sound I guess. The sound of the engine decelerating as the car slows isn't as smooth as it was w/the factory mufflers.
Old Apr 28, 2008 | 11:28 PM
1morepart's Avatar
1morepart
i have boomtubes and your concern sounds normal
Itzjoe
Aug 26, 2015 08:15 PM
Hogquad
Aug 23, 2015 05:26 AM
91StangOwner
Aug 20, 2015 11:34 PM
11GTBlu
5.0L V8 Technical Discussions
Aug 10, 2015 05:56 PM
Itstbrown
Aug 9, 2015 03:49 AM
