Backfiring issues
Old May 1, 2008 | 09:07 AM
rlh6805's Avatar
rlh6805
Default RE: Backfiring issues
ORIGINAL: H! Volt@ge
Also, the check engine light flashes if u hold the rpm at those ranges. It does not stay solid.
Flashing CEL indicates a "type A" misfire. Hook a scan tool up to it and pull the DTC's. Should be a P030x, where x could be 1-8 indicating what cylinders are misfiring. I would deffinetly NOT install any aftermarker tunes or other accessories in it until the dealer has this figured out. You don't want to give them any reason to void the warranty. IMO, it is probably a COP that is bad.
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Thunderball
15
Nov 22, 2015 11:49 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
Bokeo
Oct 10, 2015 08:28 PM
