first time at track
RE: first time at track
ORIGINAL: Seabee
also, whats some good advice for takeoff, rpms and stuff like that and should i try to do a burnout cause i have never done one while staying still
No do not burnout on your stock tires. Only if you have some sort of DRs or slicks or something
lower your pirellis to about 25 psi then after you do a small burnout just hold it at around 3krpm and let the clutch out easily. DONT dump it or you will probably kill something. I can't really explain it, it's just a feeling. I ran a 2.0 60ft on stock tires and just keep in mind not to dump the clutch. Once you feel your friction point let it out easily and you will hardly spin at all. GOOD LUCK
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
