Serious (?) Issue with my Mustang
Old May 8, 2008 | 03:49 AM
Karrmer's Avatar
Karrmer
Default Serious (?) Issue with my Mustang
The car: 2005 automatic V6
Issue: two weeks ago I start the car up, am sitting there in park idling, talking to a friend for all of 2 minutes on the phone. During the conversation the car just stalls. I turn it back on and the throttle isn't really responding and the car is chugging, the wrench light comes on and it stalls again. This light is the electronic throttle sensor thing.. I wait another 5 minutes and try again and it starts perfectly fine, drives home fine, and I haven't had any issues until today.
Today: I park my car, have it idling, grabbing a few things and then it just stalls again. Start it back up, wrench light on, stalls immediately again. I didn't try starting it and just went back into work... I am hoping it works when I go out in the morning and try to go home.
My question: Is this a serious deal? Am I boned? It has 42000 miles and I bought the lame extended warranty so I'm hoping this won't be too ridiculous... is this a common issue or is something really messed with my vehicle?
Old May 8, 2008 | 04:05 AM
lrgnation's Avatar
lrgnation
Default RE: Serious (?) Issue with my Mustang
Kind of a interesting problem which will be a pain in the a$$ to duplicate for the dealership. Just note your problems and it sounds like a fuel problem to me. Atleast that is where I would start but anyways just take it in, not a common issue but i dont think it your screwed here.
Old May 8, 2008 | 06:36 AM
Karrmer's Avatar
Karrmer
Tried again, managed to keep it idle for a good 5 minutes and then it stalled again. Frustrating.
Old May 8, 2008 | 07:15 AM
Nuke's Avatar
Nuke
Since you bought the extended warranty you might be ok. Hopefully there's a code in the PCM that the service techs can work with.
Old May 8, 2008 | 07:32 AM
moosestang's Avatar
moosestang
I bet they replace the throttle body. I wonder how many trottle bodies could have been cleaned and reinstalled, instead of replacing them.
42k miles, have you had the fuel filter replaced?
Old May 8, 2008 | 07:44 AM
Karrmer's Avatar
Karrmer
I found this TSB..
http://bradbarnett.net/mustangs/galaxie/tsb/tsb05_14_04wrench.pdf
However it says its for vehicles manufactured before 11/04 and mine says 01/05 on the sticker. I am assuming this means it is not related? The issue sounds very similar though.
Reference fuel filter changing: I got the car with 25k miles and haven't done anything besides the needed oil changes. It's my first vehicle I've owned that wasnt 20+ years old and a piece of junk so I have probably taken its reliability and "newness" for granted and neglected some maintainence work I should be doing.
Would the above also mess with my extended warranty coverage?
EDIT: Oh, also, my speedometer hasn't really worked in a while either. If the car has been running for a while it usually works OK but whenever I start the vehicle up after it hasn't been running for a while the needle usually just stays at 0 or a little below 0..
Old May 8, 2008 | 09:45 AM
Karrmer's Avatar
Karrmer
One more update... hope someone can provide maybe a little insight.
I went out after work this morning, started her up and immediately switched into drive and took off to see what would happen. It drove perfectly fine, I got home (about 15 miles) with no issue.
When I parked and put the vehicle into park it immediately stalled and shut off. Every time this has happened it was with the vehicle in park. That's when it goes down and the wrench light comes on. Is there some correlation here? Still seems to drive fine..
Old May 8, 2008 | 10:26 AM
157dB's Avatar
157dB
Cut & Paste Expert
What DTCs have been set?
Old May 8, 2008 | 10:45 AM
Johnboy7701's Avatar
Johnboy7701
Im assuming when the RPM's drop significantly it stalls, which Im pretty sure has something to do with the fuel system... give the stealership a call...
Old May 8, 2008 | 10:50 AM
sidmanic's Avatar
sidmanic
If the "wrench" is coming up, it is probably throwing a code. Sounds like what an "Extended Warranty" was made for. Take it to the dealer.
djbigskrilla
Sep 20, 2022 01:04 AM
mweiland
Aug 13, 2015 05:11 PM
drumhedd2005
Aug 13, 2015 09:59 AM
'stangdude
Aug 12, 2015 01:27 PM
daytooday
Aug 11, 2015 09:22 AM
