Sensor issues....HELP!!!
Old May 8, 2008 | 12:07 PM
mrr1999's Avatar
mrr1999
Default Sensor issues....HELP!!!
I have an 06 GT that was built by a custom shop. The engine was custom tuned with an SCT XCAL2 box. When I brought the car in for emissions, it was rejected because 3 sensors were turned off:
1. OBD Catalyst
2. OXY sensor
3. OXY Sensor HEat
I shipped my SCT back to the tuner and they re-programmed it to activate the sensorsthat wereturned off. When I brought the car in the next day after re-programming the ECM, it failed for the same reson. Is there a lag time before the sensors re-activate or something? I am stumped, and I can't register my car.
Old May 8, 2008 | 12:35 PM
rlh6805's Avatar
rlh6805
Default RE: Sensor issues....HELP!!!
You need to drive it around for a bit to enable all of the OBDII monitors to complete. Maybe 100 miles or so of combined city/hwy driving. As long as the "tuner" did his job, you shoud be ok.
IMO, if I lived in an area that required regular emissions compliance testing I would never update my veh's calibration with something that is not Fed/EPA compliant (yes there are some tuners out there that get their stuff certified).
Old May 8, 2008 | 01:09 PM
mrr1999's Avatar
mrr1999
I bought the car from Ohio. I live in Las Vegas. Maybe I should find someone locally to retune the car and save some headaches. Thanks for your input. I appreciate it.
Old May 8, 2008 | 02:39 PM
brad281's Avatar
brad281
Any chance you can run without the tunes for a while and run the stock ford? I noticed you have a procharger and I'm not sure if it's possible with the custom tune you had. There is a lag time for the comp. to cycle itself back. I don't think a local tune will help you pass your emission test either.
jwog666
Dec 27, 2021 08:09 PM
mrtrodonet
Sep 19, 2020 03:12 PM
Dathan
Oct 5, 2015 05:52 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
TfcCDR
Sep 14, 2015 12:08 PM
