Wrench and Chk Engine Problems Solved!
Old May 9, 2008 | 08:53 AM
ink003's Avatar
ink003
Default Wrench and Chk Engine Problems Solved!
i posted yesterday about my 07 stalling and popping the check engine light subsequent to limp mode. upon checking the ecu w/. my xcal2, the error code ended up being P2135, relating to the tps sensor.
so, here's the results - i brought the car in to haldeman ford in hamilton, nj. i called them in the morning, described the problem, and the service tech i spoke with told me i could bring the stang in and he'd try to fit me in. long story short, i drove over around noon, and approximately an hour later the dealership had replaced the tps and performed the airbag tsb fix. i also had mentioned to them that my passenger-side rear defroster had broken off from the glass; they ordered the replacement part for that as well. and all of this was covered by warranty and cost me zero dollars!
so, thanks to my fellow mf'ers for the good advice, and props to haldeman ford for taking care of my stang!
Old May 9, 2008 | 09:29 AM
hammeron's Avatar
hammeron
Default RE: Wrench and Chk Engine Problems Solved!
glad your story had a happy ending
Old May 9, 2008 | 10:56 AM
157dB's Avatar
157dB
Cut & Paste Expert
Glad you had some insight on the problem instead of
going in blind so the could not take you for a ride.
Old May 9, 2008 | 12:10 PM
ink003's Avatar
ink003
ORIGINAL: 157db
me too! definitely helped with the issue - as soon as i arrived i told the tech. precisely what the problem was, what code came up, and what i thought it was related to, all thanks to you guys!
djbigskrilla
Sep 20, 2022 01:04 AM
kevans79@yahoo.com
Aug 18, 2015 08:16 AM
1st 4 eyed fox
Aug 15, 2015 02:16 AM
KEM Motorworks
Aug 14, 2015 10:13 PM
stanngg
Aug 12, 2015 03:43 PM
