Rev limiter?
Old May 14, 2008 | 11:51 AM
Nuke's Avatar
Nuke
Default RE: Rev limiter?
Sorry, didn't mean to come off as defensive. Just teasing. These cars were meant to be driven and hitting the rev limiter hasn't been anything other than a rare nuisance to me (I've probably hit it 4 or 5 times in the past 10 months). It never seemed to cause anything unusual once my RPM's dropped below the setpoint.
Old May 14, 2008 | 12:41 PM
marcuskeeler's Avatar
marcuskeeler
If you want to hear a 4.6 hitting the rev limter there's no need to do it to your own ride, just watch 80% of the planks doing burnouts in their Mustangs on YouTube. With their feet planted firmly on the carpet and in 1st gear, they are incapable of controlling the revs andmerely let the limiter do the work. it's outright painful [:@]
Old May 14, 2008 | 01:04 PM
buster's Avatar
buster
rev limiter is a life saver for the motor. Stay away from it
Old May 14, 2008 | 03:29 PM
mynameismike65's Avatar
mynameismike65
ORIGINAL: marcuskeeler
+1
Last week I got on mine for like the 500th timeand after almost 1.5 years driving it I grinded 3rd and over reved it.[:@]Needless to say I was exhausted and not thinking clearly when I was doing it. Moral is I HATED the sound of my motor over reving......so why would you want to hear it on purpose[sm=badidea.gif]
Old May 14, 2008 | 04:01 PM
grampa_stang's Avatar
grampa_stang
These motors sound great at high rpms. The rev limiter is set too low. Set the limiter to 6800
and shift at 6400-6500. Haven't heard of anyone here blowing their motor due to over revving.
Theones who have blown up motors are the ones running boost.
Of course I wouldn't shift there everytime, but when you want to...she can take it.
Old May 14, 2008 | 04:53 PM
sailing220's Avatar
sailing220
Brenspeed and Bama both set my limiter at 6800.
Old May 15, 2008 | 11:58 AM
Number 13's Avatar
Number 13
"Wow, no need to get defensive.
What's idiotic is setting out to purposely hit the rev limiter, just to see what happens. Can you tell me why you would want to do this? Obviously it didn't work of too well for him is he is posting to find out what went wrong."
Why would you own a perfomance car that you intended to drive under perfomance (read: dangerous) conditions and not only want to know the cars limitations but what those limitations feel like. What i experienced was not the rev limiter buta mechanical problem with my clutch (car is in the shop right now). Iwas intentionally trying to bump the limiter to 1) verify where it kicked in 2) decide how early i needed to shift to avoid it 3) see how far back it went if i did hit it to determine stratagies to compensate if i ever miss timed it 4) understand what that felt like so I would be certain to know what was happening without having to take my eyes off the road to look at the insturment panel. The same day I also tested my breaks under heavy conditions and determined how far i'd have to go to break traction in a turn. So that wasn't the only "idiotic thing I did that day.
Old May 15, 2008 | 12:48 PM
chain1's Avatar
chain1
ORIGINAL: Number 13
If you are BRAKING (that's how it's spelled BTW) in the middle of the turn then bumping the rev limiter is the least of your worries.
Old May 15, 2008 | 02:27 PM
Number 13's Avatar
Number 13
well sure, but I think you misunderstand. I was doing those things one at a time not all at once. And yeah..."breaking" made it past my spell check while I was typing quickly at work but, thank you for both calling me an idiot and correcting my spelling, it's a refreshing change from all the flamingthat happens on internet forums
Old May 15, 2008 | 02:49 PM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: Number 13
I just got my'05 GT about a month ago. I have not had alot of time to get used to it. Took it out tonight to a nice quiet stretch of road out in the middle of nowhereand figured I'd open it up. I wanted to see where the Rev Limiter kicked in first so I left it in first and floored it...well... not a good idea. Before it hit (or after?) the rev limit it...locked up. Hard to explain but letting off the clutch was like pressing the break. Let it coast to about 5mph with the clutch open,shifted back into 1st and let off the clutch and it was like nothing ever happened. I'm new so forgive my ignorance but, what happened here? Should'nt I have bumped the rev limiter before something like that happened?
Some of these posts are funny
Yes you hit the revlimiter. In the S197 mustangs the computer simply shuts the fuel off which makes the car feel like it is turned off. It's better than the New Edge mustangs (like my old 00) where the computer would simply cause a some of the plugs to stop firing. Essentially causing a misfire storm that would bounce the engine RPM right at the limit.
I personally think this current method is way easier on the engine but a little freaky when you do it the first couple of times on accident. Is it ok to hit it? If you're broken in and it's not all the time, it won't hurt anything. If the car could't handle it, they would put the redline close to 4500RPM like some Dodge pickups I've seen in the past [&:]
You also need to remember, our cars peak HP is close to redline.
