changed interior led's
Old May 18, 2008 | 10:51 PM
wicked stang's Avatar
wicked stang
Default RE: changed interior led's
I dont know exactly how many go in the headlight switch. Havent opened it up yet. But I think it will take about 7-9 leds. I'll have to order more for the 3rd time because I forgot about them too. Make sure you definetely use a 15 watt soldering iron like it says in the how to post because i started out using a 30 watt because i didn't have a 15 watt and it was messing things up really fast.
Only thing is that i wish the my color red was brighter so it would match the leds because they're really bright and look awesome.
Old May 18, 2008 | 11:01 PM
MustangFan45's Avatar
MustangFan45
Looks good.
[IMG]local://upfiles/90468/065C45617A694927ABCF480304583D64.jpg[/IMG]
Old May 18, 2008 | 11:30 PM
vtmustangs's Avatar
vtmustangs
ORIGINAL: wicked stang
How big a difference is the brightness? I don't think a pic will be able to show it but I know on that write up the OP talked about using a lower mcd to try and match mycolor but the ones you bought seem to have the lowest mcd I have found at least for the red ones.
Old May 18, 2008 | 11:40 PM
wicked stang
The leds are quite a bit brighter, they are bright red while the my color is less bright and a little darker shade of red.
I didnt even pay attention to the mcd, I think if they were the slightest bit brighter they would kind of bother your eyes.
Old May 18, 2008 | 11:57 PM
awsomeaussies206's Avatar
awsomeaussies206
I just did blue to mine a few weeks ago. The 07's must be the same as the 08's... because I ended up not ording enough also because the AC controls needed more than the write-up showed.
Old May 19, 2008 | 11:19 AM
d_ames117's Avatar
d_ames117
The headlight switch (i believe) uses a bulb with green film.
Dustin
Old May 19, 2008 | 04:46 PM
wicked stang
ORIGINAL: d_ames117
Dustin
do you know if you can get the bulbs in different colors?
im going to be taking it apart in a couple days for sure to see what exactly ill need.
Old May 19, 2008 | 06:09 PM
blackS197's Avatar
blackS197
anyone in so cal done this? I might need some guidance. I really dont like messing with electrical stuff.
Old Jun 3, 2008 | 06:10 PM
blackS197's Avatar
blackS197
What red bulds would be the closest match?
McLeary
Mar 14, 2016 07:50 PM
Colin Ringle
Sep 15, 2015 09:27 PM
MusicCity615
Sep 12, 2015 07:05 AM
v8sn95
Sep 7, 2015 10:17 AM
