To lower or not to lower...
I here from my mustang guy that H&R springs are a way to go without losing to much in the ride area. They only drop the car between 3/4-1 inch all the way around and that doesn't cause you to have to adjust the cast or camber ( tilt of the wheel). Ive been considering them myself and have got alot of the same replies seen here.
I have Eibach Pro's and a CDC Chin. I did buy a low profile jack from Walmart for $40 and it fits under the car at the original jack points. Works great.
(It's a GM Goodwrench model though so you have to be able to look past that.)
don't forget the steeda sportor ultralites! also very popular.
less drop then the pro-kit/ford racing and bmr. and likely less harsh of a ride.
more drop then the roush springs.
my 2 cents:
cai/tune first.
lower second. as for what to do. everyone has got an opinion...
my 2 cents:
cai/tune first.
ORIGINAL: Tracedaddy
But thanks for that info. How low does it go? Do you have a model # for it?
-Jack-
This is one of those questions where almost eveyone has a different opinion on what isversus is not needed. If you want to read exhaustively on the subject here is the sticky: https://mustangforums.com/m_934501/tm.htm
If you want the short version of the majority opinion:
- Springs
- Adjustable PHB
- Dampers (Tokico D-Specs or Koni Sports are only suitable)
- some form of camber adjustment
- possibly relocation brackets - depending on drop and intended usage
- possibly adjustable UCA or LCAs - depends on drop, drive shaft being used, change in pinion angle
If you find all this confusing (believe me - I did when I first wanted to lower my car) then your best bet is to talk with a suspension expert at one of the Forum sponsors. I recommend calling Sam Strano - I think its safe to safe he is one of the foremost experts on the S197 chassis setup in the country. Real nice guy, easy to work with, reasonable prices. www.stranoparts.com
- Springs
- Adjustable PHB
