MSD Ford Launch Master (two step)
Old May 19, 2008 | 12:20 PM
Simon1's Avatar
Simon1
Default MSD Ford Launch Master (two step)
I was looking through a Summit the other day and saw this in there. It's a two step rev limiter that is adjustable. It looks like it's very easy to install, almost plug and play. You will need a switch, a drill if you can't find an existing hole to ground to and that's it.
http://www.msdignition.com/new_products/8734.html
I read the instructions and it looks like it would take less than two beers to install this.
Old May 19, 2008 | 12:31 PM
Nuke's Avatar
Nuke
Default RE: MSD Ford Launch Master (two step)
A tuner will let you change your rev limiter, speed limiter, etc.. Sounds like you need to consider a CAI & tune. Darn good reason if you ask me... LOL!
Old May 19, 2008 | 12:46 PM
2L8IWIN's Avatar
2L8IWIN
ORIGINAL: Nuke
I agree!! Over $200 and you have to drill?? No way! Tuner all the way!
Old May 19, 2008 | 01:10 PM
xxDerek's Avatar
xxDerek
I don't think you guys understand what a 2step does, it holds the engine at a certain RPM that you set, say 4000, and it holds it there steady so you launch at the right RPM every single time, like it says in the description, just drop the clutch and go... if you need some visuals go to youtube and type in 2step, plenty of videos on it... I'm actually surprised there is one for our cars, but I've heard they're pretty dangerous for the engine..
Old May 19, 2008 | 01:36 PM
GOTTORQ's Avatar
GOTTORQ
^^ thats exactly what it does..it most cases "two step" or launch control is used in a turbo car..more or less the evos and subys to build boost at a dead stop so ur launching under boost rather than trying to build boost off the line
Old May 19, 2008 | 01:56 PM
xxDerek's Avatar
xxDerek
ORIGINAL: GOTTORQ
Yea, I forgot to add that that is why I'm surprised. Usually a 2step is to spool the turbo, which in your case Simon is great, for most of us it's not really necessary, but still nice I guess...
Old May 19, 2008 | 01:59 PM
Simon1's Avatar
Simon1
ORIGINAL: GOTTORQ
That would be me, a turbo car.
Boost won't be built until there is a load on the turbo, but it gives a car, any car, launch at the RPM choosen by the driver. This gives the driver the ability to concentrate more on the lights and the clutch slip.
Some hand held tuners are capable of two step programing, some/most aren't. The nice thing about this application is the adjustability factor. The simple turning of a ***/dial to a lower/higher rpm.
Most Auto trannies don't need a 2 step, but some do. Depends on the application.
Old May 19, 2008 | 06:11 PM
Green08BulliTT's Avatar
Green08BulliTT
youcan build boost in a car with out load. you have to mess with the timing but it can be done. alot of 2steps alow a timing adjust while your in the locked rpm. its not great for turbo life since it makes alot more heat and added stress.
Old May 19, 2008 | 07:08 PM
DarkFireGT's Avatar
DarkFireGT
Actually, many racers use a 2 step. As stated above, it lets you focus on the lights and clutch, and not RPMs. The stock rev limiter pulls fuel. Very bad. It also is not consistant, and you can't have a different setting for neutral and gears (it has the option, but doesn't work). The MSD 2 Step allows you to dial in exactly where you want your RPMs at with the clutch down. It keeps it there by pulling spark, and the RPMs are VERY consistant. I will be ordering mine in the next few weeks.
Old May 19, 2008 | 07:50 PM
NyFordTech's Avatar
NyFordTech
heres a nice vid
http://www.youtube.com/watch?v=pMvWY...eature=related
