MSD Ford Launch Master (two step)
ORIGINAL: Intervention
You can get the 2 step to wrok with the tuner.
All you need to do is tape down the upper clutch switch, and have your tuner enable 2step in his tune.
Works perfectly for me
The thing about this set up, is there is an on/off switch. You don't have to load and unload a tune.
$200 seems pricey.
I really don't see the need to be able to turn the 2 step on and off. It only activates when the clutch is depressed (or brake), and all it does is limit the revs to the set limit.
waid302
Sep 14, 2015 11:19 AM
