Line-lock (quick read)
With all the supplies needed, they come to about $185. Not sure on the legality, but it doesn't impede every day driving, so I wouldn't worry about it.
If you want to see how they're installed, here's my write-up.
http://www.stangnet.com/Tech-Article...ll-080225.html
If you get the SLP kit, everything is there. You just need the brake fluid for when you bleed the brakes. Also, I learned if you do not undo the cap before hand. The fluid will not drain out of the bottom of the hole. I had a full reservoir, undid the line and nothing dripped out. Just the fluid that was already in the lines
ORIGINAL: TJMJoe
Are they expencive?
Are they illegal? (ive been told)
Thanks!
Are they expencive?
Thanks!
I have ABS, so I used dual solenoids, with each onemounted inthe corresponding wheelwell. I'm not 100% satisfied with the switch location (I mounted it on the overhead console). Other locations would be replacing the dummy slot where the 2008 seat heater switches are (between the A/C and max A/C buttons) or in the upper right corner of the headlight switch. You can also wire a toggle switch to make your cruise control or headlight dimmer activate your linelocks.
Sep 18, 2015 12:25 PM
