Tire Help
Old May 23, 2008 | 08:38 AM
hooverimg's Avatar
hooverimg
Default Tire Help
I have 20 inch X 8.5 inch rims, and the car is lowered 1.5 inches. I currently have the following tire setup 20/35/255 in the front and back. Does anyone know if I can get a pair of wider tires on the front and back with my current rim width?
I would like to go with 20/35/275 in the front and back....will this work?
Old May 23, 2008 | 08:53 AM
2007REDFIREGT's Avatar
2007REDFIREGT
Default RE: Tire Help
275/35/20 on all 4 corners will work. Saleens run this size. You can also run either 245 or 255/40/20 on all 4 corners and this will give a little more sidewall and this makes it ride a little smoother.
Old May 23, 2008 | 10:27 AM
hooverimg's Avatar
hooverimg
ORIGINAL: 2007REDFIREGT
Thanks...does anyone know the largest tires that will fit on the front & back of a 8.5 inch rim....can I go larger than 275?
Old May 23, 2008 | 11:59 AM
waykooljr's Avatar
waykooljr
ORIGINAL: hooverimg
Recommended rim width for 20/35/275 is 9-11"
jwog666
Dec 27, 2021 08:09 PM
CS2007
Jun 25, 2019 09:45 PM
KingRando
Oct 2, 2015 08:06 AM
marc954
Sep 29, 2015 11:18 AM
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
