New Exhaust Idea?
Old May 27, 2008 | 07:59 PM
DarkFireGT's Avatar
DarkFireGT
Default RE: New Exhaust Idea?
I like the description. I might try changing out the Magnaflows in my '05 with the Cervini's kit. The trumpeting is terrible.If you want the Pypes MMS sound, Summit sells the M80's for under $50/each. That's what they use with the MMS system. I've thought about those, too, but they're a straight through, and I think that's the problem I'm having with the Magnaflows. Looks like Gibson also makes some in 20" length (same as the M80s and Magnaflows), and 4" diameter so they'll fit well, but they're $200/ea!
Old May 27, 2008 | 08:15 PM
ryanralston07's Avatar
ryanralston07
I just want my car to sound like the previous generation of mustangs
Old May 27, 2008 | 08:20 PM
Norm Peterson's Avatar
Norm Peterson
ORIGINAL: iluvmycar
Am I wrong or does it not say they are not for the 2005+ mustangs?
Once you step up to doing your own custom fabrication it doesn't much matter what the parts guy's book says it belongs on. Only whether it will fit up, fit in the available space, and meet whatever criteria you're looking for. Traditional grass-roots level hotrodding was not a checkbook/money/no-brain-required plug'n'play game; those guys would understand.
Norm
Old Jun 3, 2008 | 05:45 PM
Stage4's Avatar
Stage4
i'm actually running this exact setup - SLP LM's mounted under the car. I have no cats, but this is all after the turbo, so I'm sure a stock setup would sound different. Ground clearance has been the issue, they scrape on quite a bit. I hit a dead raccoon the other day, and it drug it probably 100 feet down the road... egh....
anyway - here's a clip
http://www.youtube.com/watch?v=DRKI5xvFAUg
ak98
Feb 18, 2023 08:36 AM
Sep 10, 2015 08:39 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
Emblazoned
Sep 3, 2015 10:45 PM
