Driveshaft replacement
Old May 27, 2008 | 04:22 PM
larryvaughn's Avatar
larryvaughn
Default Driveshaft replacement
Replaced the OEM 2-piece driveshaft with the Shaftmaster 3.5" aluminum one with adapter plate. Followed TacoBills directions, and it was a piece of cake. Have since run it up to 90mph with no vibration,no noise, no clearance issues.My pinion gear angle is at 1 degree up, the shaft is at 3 degrees up, and the trans is at 2 degrees up. This complies with the Ford maintenance manual which says the front and rear net angles should be within 1 degree of each other and no more than 3 degrees total.
Not so lucky with my new upper control arm. See subsequent post.
mtgldr
Feb 3, 2024 09:00 PM
Galactic
Apr 29, 2019 02:56 PM
5.0muscle
Jan 11, 2016 01:17 PM
Luke9222
Oct 22, 2015 11:55 PM
angeljoelv
SVT Forums
Sep 10, 2015 09:12 PM
