Sponsored by:
Sponsored by:
Installing GT500 Spoiler from The Spoiler Store
Old 06-06-2008, 01:33 PM
jdmcbride
jdmcbride's Avatar
Default Installing GT500 Spoiler from The Spoiler Store
My GT500 spoiler should be delivered today! I can't wait to get it on the car.
I do have a question for those who have installed spoilers...
How did you prep the paint on the trunk that will be under the spoiler?
A. Strip off the wax so the 3M tape will stick better
B. Put a fresh coat of wax on
C. Do nothing but clean where the spoiler goes
Thanks in advance!
JD
jdmcbride is offline
Old 06-06-2008, 01:39 PM
mdg
mdg's Avatar
Default RE: Installing GT500 Spoiler from The Spoiler Store
No need to take off or apply wax. Just make sure the trunk lid is clean, and clean with alcohol. Are you drilling holes?
mdg is offline
Old 06-06-2008, 01:57 PM
jdmcbride
jdmcbride's Avatar
ORIGINAL: mdg
Won't the rubbing alcohol take the wax off?
I decided not to drill the additional holes. Many have said that they have had no problem without drilling the additional holes.
Old 06-06-2008, 02:02 PM
nm3
nm3's Avatar
I used a Ditzler wax/grease remover that I had in my cabinet.
nm3 is offline
Old 06-06-2008, 02:12 PM
Javdog
Javdog's Avatar
Do you currently have the stock spoiler? I had the stock spoiler on mine and I used fishing wire to remove mine I had someone pull up on the stock spoiler while I sprayed some Meguiars detailer under the adhesive and used the fish wire in a back and forth motion to seperate the adhesive and stock spoiler from the trunk make sure you use something to lubricate the fish wire if you dont have some kind of detail spray use some soap and water it came off pretty easy, cause it is taped on pretty strong. Hope this helps. Here are some pictures of theShelby spoiler on a black vert. From the Spoiler Store.
Javier......
Javdog is offline
Old 06-06-2008, 02:56 PM
mlcrycc
mlcrycc's Avatar
My process was......(and this is after removal of stock spoiler, and clean up of the goo gone...)
Wash entire trunk lid with normal car washing soap
Clean 3M contact area with rubbing alcohol, or if available adhesive promoter
apply new spoiler, and tighten down
apply new wax and polish to exposed areas
No problems thus far......
Mike
mlcrycc is offline
Old 06-10-2008, 11:37 PM
1morepart
1morepart's Avatar
good advice
1morepart is offline
Old 06-11-2008, 04:36 PM
Ato
Ato's Avatar
I just installed mine the other day, looks and fits great, although I have 2 minor problems. First I somehow scratched the hell out of the left side trunk near the holes for the stock spoiler but it still shows where the gt500 one is (have no idea how I did it, but I'm sure a good buffing will fix that). Second, the tape on the gt500 spoiler didn't really make contact and stick on the sides, this really don't much matter though since the whole front and rear stuck really well so I don't think it going anywhere. Overall I'm pretty happy with it.
Ato is offline
mtgldr
02-03-2024 09:00 PM
Galactic
04-29-2019 02:56 PM
carid
07-08-2016 09:55 AM
Other Professional Racing
09-10-2015 11:41 AM
Quick Reply: Installing GT500 Spoiler from The Spoiler Store
