Lowered and alignment
Old Jun 14, 2008 | 07:07 PM
bchataroo's Avatar
bchataroo
Default Lowered and alignment
Anyone get an alignment with lowering springs? Everywhere I go they say they cannot align the car because it is lowered.
Later
Old Jun 14, 2008 | 07:32 PM
Tormentor's Avatar
Tormentor
Default RE: Lowered and alignment
yes I had mine aligned, I installed the Ford Racing Springs, Shocks and Struts about 2 months ago and had to take it to SutonHigh Performancefor the alignment, couldnt get the car up the ramps at regular dealership
Old Jun 14, 2008 | 07:42 PM
Heavyg72's Avatar
Heavyg72
Yes it was part of the install of my springs. I would recommend the alignment as I had to adjust the camber afterwards.
Old Jun 14, 2008 | 09:10 PM
Vertigo's Avatar
Vertigo
ORIGINAL: bchataroo
Later
Thats BS its there job to correct the problem. Some shops do not have bolts to correct negative camber. When i lowered mine i used bolts and about one month later the driver side bolt started to walk out of it spot. I upgraded to steeda plates and i havent had a problem yet.
Old Jun 15, 2008 | 12:10 PM
ErcWrestlr's Avatar
ErcWrestlr
ORIGINAL: Vertigo
ORIGINAL: bchataroo
Later
Not to thread jack, but how did you know the bolt was walking out of its spot? I thought this could happen and want to make sure I can check it out. Thanks!
Old Jun 15, 2008 | 12:53 PM
dschmink's Avatar
dschmink
guess you should put some locktite on it til you can afford/want to spend the money on camber plates
Old Jun 15, 2008 | 05:31 PM
Vertigo's Avatar
Vertigo
ORIGINAL: ErcWrestlr
ORIGINAL: Vertigo
ORIGINAL: bchataroo
Later
Unless you have some beefy cambolts they can walk out over time. I got my bolts from brenspeed sure they worked for a while but one day i walked out to my car and saw my front tire leaning. So i took a peek around make sure i didnt break something. I took it for a drive and it pulled to the right a bit. The steeda plates are only $200 or so and will not walk out on you.
lincolnshibuya
Jul 5, 2020 03:05 AM
winner99
Sep 30, 2015 07:04 PM
Drastang
Sep 29, 2015 03:31 PM
marc954
Sep 29, 2015 11:18 AM
lincolnshibuya
Sep 24, 2015 10:46 PM
