belt problems help!!!!
Old Jun 23, 2008 | 08:40 PM
modaddict's Avatar
modaddict
Default RE: belt problems help!!!!
I don't think that's the case (walking on the ac) cause it would be definitely due to misalignment, and if it was walking there, you'd be able to easily see the misalignment visually just looking the pullies from an angle.
My guess is that it is subtle.
Old Jun 23, 2008 | 08:44 PM
fadetoblack172's Avatar
fadetoblack172
how would you go about checking the alignment or finding the problem modaddict??
Old Jun 23, 2008 | 08:50 PM
modaddict's Avatar
modaddict
First of all - did you install it yourself or have a shop do it? If a shop did it, then how many other kits (on S197's) have they installed without any issues?
Second, one thing that bothers me in the pics you posted is that your idler looks off and it appears as if the belt is riding the edge of the pully. This may just be because of the angle however, I don't think so cause I can see the belt wear on the pully and it's definitely on the edge. I would look here first and foremost...
(the idler I'm speaking of is the sliding idler under the blower pullie)
Old Jun 23, 2008 | 08:54 PM
fadetoblack172
i had cj pony parts do all the work and they've installed 15 of these kits, i dont think its the idler although i could be wrong
Old Jun 23, 2008 | 08:57 PM
modaddict's Avatar
modaddict
Perhaps - I'm just looking at your pics and not your car but I do know it's obvious from the pic that your belt is riding the edge of the idler and this will chew or toss a belt garunteed sooner or later...
Where you missing any ribs off the belt you lost?
Old Jun 23, 2008 | 08:59 PM
fadetoblack172
yea i know that but the belt had and has no sign of wear whatsoever it it only a month old and i checked it it doesnt ride the edge
Old Jun 23, 2008 | 09:01 PM
modaddict's Avatar
modaddict
Okay - maybe the pic is just deceiving.
Lastly, here is the million dollar questions - do you have an auto or manual? And most importantly, did you lose the belt an accel or decel? (decel = right when you let out of the gas)
Old Jun 23, 2008 | 09:02 PM
hammeron's Avatar
hammeron
agreed. i'm pretty sure the monster tensioners
use the stock spring, so maybe just having a
tensioner that doesn't warp, is the key to
long lasting happiness
ORIGINAL: modaddict
a tensioner like peters is much more 'forgiving' of any issues
so for most guys the easy 'fix' is usually a better tensioner.
Idler is #2...
Old Jun 23, 2008 | 09:03 PM
fadetoblack172
actually there are alot of fibers from the belt around the sliding idler area
Old Jun 23, 2008 | 09:04 PM
fadetoblack172
it's a 5 speed and all 3 belts broke on a 2-3 shift or 3-4 shift at WOT not speed shifting though
