Intercooler Leaking?
Old Jun 25, 2008 | 12:45 AM
egon's Avatar
egon
Default Intercooler Leaking?
Has anyone had a leak with their water-to-air intercooler (regardless of s/c brand). I noticed that my intercooler reservoir was low, but there is no visible sign of a leak. I'm assuming that it can leak internally and get consumed with the air/fuel, but how to you tell?
Any suggestions will be much appreciated.
Old Jun 25, 2008 | 08:56 AM
05 Mustang's Avatar
05 Mustang
Default RE: Intercooler Leaking?
mine leaked when it was first installed...where the fittings screw into the heat exchanger, at the top, but there was a small puddle under the front of my car that gave it away....
Old Jun 25, 2008 | 09:27 PM
egon's Avatar
egon
Humm... yeah, no visible leaks that I've been able to find and I'm not totally sure it is leaking. The level just dropped on me and I'm not sure why. Haven't had it installed that long, and with the recent warm weather I'm wondering why the level changed.
Anyone else with experience with this?
Old Jun 25, 2008 | 10:32 PM
hammeron's Avatar
hammeron
top it off for a few drives and if it
keeps droppping, then i would say
yes there is a leak somewhere
there may have been an air bubble
somewhere in the system
Old Jun 25, 2008 | 11:45 PM
egon's Avatar
egon
Yeah, was wondering if that might be the case. I'll keep and eye on it and see.
If I am leaking coolant internally and it is getting into the combustion chamber, how can I check for this? Will the spark plugs show signs? Exhaust pipes show evidence?
Thanks again for the advice!
Old Jun 26, 2008 | 09:32 AM
2L8IWIN's Avatar
2L8IWIN
Check your oil.....it would look milky on the dipstick
Old Jun 26, 2008 | 09:49 AM
hammeron's Avatar
hammeron
egon, i'm not sure you're going to see
any good evidence looking at the plugs
or exhaust. maybe the oil like 2L8 says,
if it's discolored enough....
the only sure fire way to tell, would be
doing a leakdown test of the core
Old Jun 26, 2008 | 10:26 PM
egon's Avatar
egon
Thanks everyone for the suggestions. Oil looks good right now. I'll keep and eye on it, and if it keeps dropping I'll do a leak down test.
Cheers!
jerrytubes
Oct 23, 2015 12:11 PM
Bokeo
Oct 10, 2015 08:28 PM
Explosive
Oct 2, 2015 07:45 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
