problem shifting into 3rd?
Old Jul 10, 2008 | 12:12 PM
thrift's Avatar
thrift
Default problem shifting into 3rd?
okay; i've got an 08 Gt manual. if i really get into it; and try to quickly shift into 3rd; it seems like i "catch" the spot between 1st and 3rd. (the separator between the gears) and i have to bring it back into netural and try 3rd again.
i hope that makes enough sense where you understand. is this a common problem? maybe something a driver mod will fix? something a STS will fix?
or is this just a problem with a loose nut behind the steering wheel?
Old Jul 10, 2008 | 12:14 PM
dschmink's Avatar
dschmink
Default RE: problem shifting into 3rd?
Sounds like driver mod to me. Just practice your shifts and get the muscle memory down and you'll have no problems.
Old Jul 10, 2008 | 12:16 PM
buster's Avatar
buster
some put a new shifter in. I just shift slower into 3rd on the track. It's your choice, its your car
Old Jul 10, 2008 | 12:20 PM
Ruffnuts's Avatar
Ruffnuts
This is a common problem for alot of people. Practice may help but an aftermarket shifter will fix this. As fas asI know there isn't any mod to the existing shifter that can fix this.
Old Jul 10, 2008 | 12:26 PM
Riptide's Avatar
Riptide
Seems like I've read about people here with aftermarket STS having the same problem. They were told to get motor mounts.
Old Jul 10, 2008 | 12:28 PM
thrift's Avatar
thrift
haha. so buy a shifter. have same problem. buy motor mounts then. possibly have same problem again? lol. sounds like i need to get a driver mod before i do anything.
never had any problems with my past manuals; but they were a cobalt and an old jeep wrangler....
Old Jul 10, 2008 | 12:49 PM
Solitear's Avatar
Solitear
ORIGINAL: thrift
i remeber frist learning stick (*The horrors the unspeaable horrors*) but yea once you have it down muscle memory will kick in and work.
Old Jul 10, 2008 | 12:59 PM
AmericanSpeed's Avatar
AmericanSpeed
When the tranny torques under hard load, it can make it more difficult to find the gear, its pretty common. Some people will suggest motor mounts and/or a k-member brace with torque limitors that attach to the tranny.
Old Jul 10, 2008 | 04:09 PM
abrush's Avatar
abrush
Yes, a k-member with torque limitors is a good option. I purchased the CHE as is was recommended by several people on this forum. It helps elimate the twist that your tranny is enduring during hard acceleration.
Old Jul 10, 2008 | 06:27 PM
howarmat's Avatar
howarmat
s197 Junkie
Amber is correct, K member brace and torque limiters will keep the tranny under control and you shouldnt have he problems anymore.....motor mounts help also. A new shifter is not the answer to this problem.
