Wheel/Tire Fitment Question...
Hey folks, I’m looking at swapping out my stock wheels with something different. If I do, I want to keep the same times since they only have about 5k miles on them. The tires I have on the car are the ones that came with the car 235/50ZR18s. The wheels I have I think are 8.5 inches wide while the wheels I want are 9 inches wide. Would my stock tires work ok on a slightly wider rim or would I need to swap out tires if I got those 9 inch wide rims?
According to the tire calculator (http://www.1010tires.com/TireSizeCalculator.asp) the answer is no, 235/55/18 rim widths are 6.5 - 8.5
He said 235/50/18 not 235/55/18. But the answer is still the same, no 235/50/18 6.5"-8.5"
1/2 an inch really isnt going to be a major problem, but it does go against the recommended size by a half an "
Hmmm.. thanks for the info guys. I'd really like to get the wider rims, but if they'd neccessitatenew tires I'll probably just get rims that fit the stock tires.
ORIGINAL: Stoenr
Or just wait until its time for tires.......... Those look great with that color.
To speed up the process, I'm afraidI'd be doing lots of burnouts...
ORIGINAL: Steve O Chap
Stick with what ya got now and when its time for new tires, maybe
you will have enough saved up for 9" wide rims and the proper tires.
I just stuck 255/45-18s BFG G-Force KDW-2s on the 18x8.5 50mm
offset stock bullits and they are super looking.
[IMG]local://upfiles/69445/637390BABF044468970CA4D82612B80C.jpg[/IMG]
carid
Aug 25, 2015 08:17 AM
