VIN decode
Old Jul 14, 2008 | 09:08 AM
mnjettr's Avatar
mnjettr
Default VIN decode
newb here looking for some help.. I need to find out if in fact the car I'm looking at has the (factory installed) pony package?? I tried a search on this site but came up with nothing for VIN decoding.
its a 2006,1ZVFT80N865136753 thanks for any help. this is a great site...........
Old Jul 14, 2008 | 10:07 AM
GidyupGo's Avatar
GidyupGo
Default RE: VIN decode
Can't help except to say, if the car has a PP, it probably came that way. Some on here are changing their front end look to a GT style. I doubt they would settle at upgrading to a PP.
Old Jul 14, 2008 | 10:28 AM
mnjettr's Avatar
mnjettr
ORIGINAL: GidyupGo
Ya, I think your right. I was interested to see if there was a vin code to designate the PP. thanks
Old Jul 14, 2008 | 01:57 PM
JRT1's Avatar
JRT1
https://www.fleet.ford.com/maintenan...ls/default.asp
Put your VIN in here but it doesn't tell you much.
You can probably contact Ford to find out what it came with.
Old Jul 14, 2008 | 02:15 PM
Orion_240's Avatar
Orion_240
I'm not seeing any info on how to decode new Mustang VIN numbers. Not like the old code plates that would tell you about all the options.
One site said that you will only be told other things that would match up with a factory Pony Package. Like you won't find a real one on any GT. I'd recommend comparing it to a known Pony Package.
In the 2006 Mustang brochure it says it comes with:
Pony grill and fog lamps, rear spoiler, chromed air vent surrounds, 17" painted aluminum wheels with Tri-bar Pony center caps, Pony fender badges, MUSTANG side stripes, Mustang badge on the floor mats, anti-lock brakes and Traction Control.
That means it will be pretty hard to clone a Pony Package!
Old Jul 14, 2008 | 02:58 PM
mnjettr's Avatar
mnjettr
ORIGINAL: Orion_240
thanks, your right it would be difficult to clone. I plan to go look and hopefully buy the car weds. the car is located several hours away so I want to get as educated as possible about this car, its been 28 years since I owned a mustang. thanks for all the help............
Old Jul 14, 2008 | 06:19 PM
157dB's Avatar
157dB
Cut & Paste Expert
http://iihs.net/fsm/?dir=44&viewfile...on%20Codes.pdf
If it has an 18mm rear anti sway bar, its a PonyPackage or
a V6 with a PP rear sway put on it.
No rear anti sway bar, its either been removed or its a V6 non-PP.
Or if it has a 20mm rear sway, it has a GT-take-off rear anti sway bar.
Old Jul 15, 2008 | 06:03 AM
EricM's Avatar
EricM
ORIGINAL: mnjettr
There is no VIN designator for PP. Ford has a database with option info for a VIN though. Here's what your VIN means:
1ZV - Ford passsenger car
F - driver/passenger airbags (H - front and side airbags)
T80 - coupe (T82 - GT or Shelby GT Coupe; T84 - convertible; T85 - GT vert; T88 - GT500 coupe; T89 -GT500 vert)
N - 4.0L 210 HP V6 (H - 4.6L 300 HP V8; S - 5.4L 500 HP V8)
8 - check digit
6 - 2006
5 - Flat Rock Assembly Plant
136753 - sequential
Old Jul 15, 2008 | 06:21 AM
partsbill's Avatar
partsbill
just ran your vin# and pulled up a build sheet for your car, it is a Pony Package.
Old Jul 15, 2008 | 08:26 AM
mnjettr's Avatar
mnjettr
ORIGINAL: partsbill
COOL, thanks partsbill....
Jonnyyuma
Oct 4, 2006 02:13 PM
ironh19
Mar 2, 2005 11:42 PM
wildswing
Sep 26, 2004 08:13 PM
67aquafastback
Nov 17, 2003 11:59 PM
