Dealer service
Dealer service
opinions on this?
i'm bringing my 08v6 to dealer for it's 2nd service toay at noon.
last time i brought it the car felt so much better. though people say dealers are bad etc.
what is the general concensus on free service at the dealer?
RE: Dealer service
ok so back form the dealer. i marked the oil filter with a marker though the marking would be on the other side if they decided to jsut spin it around. but the oil filter is dirty. is that normal? and there is a little oil leak right under the filter. can anyone tell me if this is normal or not?
and also this caught my eye:
something seems missing. the area pictured is the top right corner of the engine bay. those white rings around the pipes are loose. is somethign supposed to go there?
RE: Dealer service
ok sweet i never noticed before which is why i was having doubts.
though with the dirty filter and leak under it (not onto my driveway but onto whatever part of the frame is under there) is that ok?
RE: Dealer service
have you removed the filter to check to see if the mark you made is indeed on the other side?
perhaps they replaced the old one with a new one that was sitting around and got dirty, but the leak isn't good. i hope it's not cross-threaded. since i doubt you want to drain out all the new oil to check the filter, i might bring it back to the dealership and tell them about it.
RE: Dealer service
The plastic clips in the pics are normal and left over from the install of the AC lines. Most cars will have them. You can cut them off.
The oil on the oil filter...is actually a leak or a couple of drops left over? Wipe it off and see if it comes back. If it comes back it's not normal. If it's gone then it was from when they filled the filter before putting on the car. It's known as priming the oil filter.
