Sponsored by:
Sponsored by:
Oil Change Time
Old 07-22-2008, 09:01 PM
kaponelb
kaponelb's Avatar
Default Oil Change Time
its time to change my oil i have 16636 miles on my car and i wanted to know if i gotta change anything else and what oil should i go with i was thinking royal purple
kaponelb is offline
Old 07-22-2008, 09:02 PM
sonicmetalicS197
sonicmetalicS197's Avatar
Default RE: Oil Change Time
Nope, your good to go w just oil
Royal Purple FTMFW worth the extra few $ in my book
sonicmetalicS197 is offline
Old 07-22-2008, 09:13 PM
kaponelb
kaponelb's Avatar
so oil filter and just oil when do you change other stuff in the car so the royal purple its worth the extra cash
kaponelb is offline
Old 07-22-2008, 09:48 PM
downriverT
downriverT's Avatar
red loctite
downriverT is offline
Old 07-22-2008, 11:14 PM
Androdz2
Androdz2's Avatar
God this has been debated so many times. #1 avoid royal purple there are way to many stories of it failing and causing engines to fail just use the search engine. #2 use 5w-30, 5w-20 was recommended for cafe standards if in doubt just see what roush and saleen recommend on their engines... They recommend 5w-30 funny how the oil recommendation changes when cafe standards are no longer in play. And not only that one of the engineers that was on the s197 engine design team has explicitly said that 5w-20 was recommended for mileage reasons.
Andrew
Androdz2 is offline
Old 07-22-2008, 11:30 PM
sailing220
sailing220's Avatar
Androdz2, the search engine is still not working properly (at least not for me). Give him a break. 5w-20 will work fine in our cars, as will 5w-30. I used Royal Purple for a couple of changes and had no problems, but changed back to Mobil 1 because I didn't notice any difference with the RP so I couldn't justify the cost.
sailing220 is offline
Old 07-22-2008, 11:38 PM
kaponelb
kaponelb's Avatar
yeah search engine dont work that the reason for postin thanks sailing220 ima go with mobil one 5w-30
kaponelb is offline
Old 07-22-2008, 11:48 PM
sailing220
sailing220's Avatar
Good choice. That is what I'm running right now (full synthetic) and I've had no problems.
Old 07-22-2008, 11:55 PM
Androdz2
Androdz2's Avatar
ORIGINAL: sailing220
Oh I didn't know it wasn't working my bad. Royal Purple 5w-20 doesn't pass gf-4 specs and has been found to be the cause of premature engine wear and ultimate failure. 5w-20 trades off protection for a fraction in mpg. It doesn't sound as a lot but when you are talking about a whole production of cars it ends up being a massive #. 5w-20 is not enough for our cars, I have seen many oil analysis showing 5w-20 breaking up and loosing viscocity. An engineer that practically designed the 4.6 3v recommended to never use 5w-20. So in this case I am going to listen to the person that was part of the engine design crew. NOt only that amsoil clearly states 5w-20 is not recommended for our engines and so has redline. BTW redline/amsoil are the two best oils out there.
Andrew
Androdz2 is offline
Old 07-23-2008, 12:11 AM
sailing220
sailing220's Avatar
Oh, I was running RP 5w-30. I switched to 30 at the first oil change.
I've been using Mobil 1 but I've heard so much good stuff about Amsoil I'm tempted to switch next change.
Quick Reply: Oil Change Time
