Wire routing engine compartment
Old Jul 28, 2008 | 04:03 PM
smythge's Avatar
smythge
Default Wire routing engine compartment
Where is the easiest place to run wires from the engine compartment to the inside?I've got my line lock running through the hood release cable, and that was PITA to get my hands in there. I am in the process of hooking up my window switch & purge, and need to find an easier way to run the power wires. Pics would be appreciated.
Old Jul 28, 2008 | 05:09 PM
mikeysGT's Avatar
mikeysGT
Default RE: Wire routing engine compartment
there's a hole in the firewall right in the driver side of the engine bay.. not sure what wire is running through there but that's where i just ran my nitrous wires from... ill take some pictures later..
Old Jul 28, 2008 | 05:34 PM
Dragon Stang's Avatar
Dragon Stang
If you look up under the passenger side, on the bulkhead, you will see a nice oval grommet with wires coming through. Typically, there is an empty nipple there that could be utilized.
[IMG]local://upfiles/78734/6BED6F2B9154455D9B334B8C08164A21.jpg[/IMG]
Old Jul 28, 2008 | 06:06 PM
smythge's Avatar
smythge
Thanks for the picture, I'll go out and take a look!
Old Jul 28, 2008 | 06:25 PM
DarkFireGT's Avatar
DarkFireGT
Yep, that's where I ran the wires for my line lock and 2 step. There's one on each side.
Old Jul 28, 2008 | 06:29 PM
smythge's Avatar
smythge
ORIGINAL: DarkFireGT
Ok I see them inside the car, now where do I access those in the engine compartment?
Old Jul 28, 2008 | 06:35 PM
mlcrycc's Avatar
mlcrycc
You can also access one under the drivers side, above the brake and clutch. Then if you peel back the drivers side fender well lining, and this is what you will see. The green wire you see is from my Raptor, going right into the open area under the master brake cylinder....
Mike
[IMG]local://upfiles/13557/D7761C629FFE421ABD7D91A006A18853.jpg[/IMG]
Old Jul 28, 2008 | 06:43 PM
smythge's Avatar
smythge
Thanks for all the help now I've 2 good spots to get the wires from the switches to the engine compartment, my next question is the fuse block in the car on the passengers side has several unused slots, do these have power running to them?Can I simply use an add a fuse to tap into them?
Old Jul 28, 2008 | 07:04 PM
mlcrycc's Avatar
mlcrycc
Yes. Just check your owners manual, and it will tell you which slot is for what, and from that, you can tell if they are switched or unswitched.....
Mike
djbigskrilla
Sep 20, 2022 01:04 AM
Aggiebq86
Sep 4, 2015 12:20 PM
Philhampton1
Aug 21, 2015 12:04 PM
Hillbilly1968
Aug 19, 2015 12:03 PM
bigdaddy51200
Aug 19, 2015 05:09 AM
