Pedal Sticking
Old May 10, 2005 | 08:24 PM
brad810's Avatar
brad810
Default Pedal Sticking
I have a 05 Mustang GT w/ 500 mles on it and the throttle sitcks. Has any one else had any problems like this. I checked the pedal , but could not find out why is is sticking. I heard the throttle is fly by wire , so I dont know how it can stick.
Old May 10, 2005 | 08:33 PM
dukenitro's Avatar
dukenitro
Default RE: Pedal Sticking
FIRST TAKE THE GUM OFF THE FLOOR.
CHECK YOUR FLOORMATS. SOMETIMES THEY TEND TO JAM THE PEDAL. AND ITS DRIVE BY WIRE INSTEAD OF FLY BY WIRE. THEN AGAIN MAYBE YOUR CAR FLYS TOO.
Old May 11, 2005 | 01:13 AM
don_w's Avatar
don_w
I ♥ Acer
Mine sticks too...
... in between my right foot and the floorboard. YEEHAW!![sm=gears.gif]
Old May 11, 2005 | 01:46 AM
hawgman's Avatar
hawgman
I ♥ Acer
This is someone elses signature file from a different board, so I give credit to 05GT on The Mustang Source Forum. But still thought it was funny, and fit well with this thread.
We figured out the problem with the tire wear. You see the tread on your tire works a lot like the sidewall does. When you let all the air out of a tire, the sidewall goes flat, and is no longer usable. If you let all the smoke out of a tire, then the tread goes flat, and is no longer usable. Now I'm not gonna tell you to quit letting the smoke out of your tires or anything like that, I just wanted to make sure that you are well educated on the workings of the modern high performance tire.
Old May 11, 2005 | 01:52 AM
Shifty's Avatar
Shifty
Is the pedal sticking? Or just the throttle? If it's just the pedal than clean it. If it's the throttle get a flash or have someone check it for you if you don't want to check it out.
Old May 11, 2005 | 02:12 AM
don_w's Avatar
don_w
I ♥ Acer
ORIGINAL: hawgman
That explains a lot... thanks for the education hawgman.
Old May 11, 2005 | 10:35 AM
ChristopherCamel's Avatar
ChristopherCamel
id have to say its something wacky with the computer because it is all electronically controlled..mine doesnt stick at all
Old May 11, 2005 | 11:00 AM
Professor Wizard's Avatar
Professor Wizard
MF Moderator
I wonder of you can pump smoke back into the tires!
Once you let all the smoke out of the tire with your mustang - can you still use the tires on a Toyota?
Thunderball
15
Nov 22, 2015 11:49 PM
BeatnikFink
Oct 1, 2015 08:00 PM
wraith777
Sep 28, 2015 10:49 AM
ThatJuanStang
Sep 25, 2015 08:01 AM
ccdguy
Sep 19, 2015 05:20 PM
