Quick help needed. FRPP GTA install
Old Aug 10, 2008 | 02:54 PM
tjs2906's Avatar
tjs2906
Default RE: Quick help needed. FRPP GTA install
I agree with the "weld them on suggestion. I am going to have my welded, I just haven't had time.....I've had seven weekends off this year................ No, I'm not kidding
Old Aug 10, 2008 | 04:17 PM
rlh6805's Avatar
rlh6805
ORIGINAL: smythge
Get some clamps like this http://www.jegs.com/i/JEGS/555/30732/10002/-1 that is the only way I got my GTAs to seal.The GTAs aren't expanded deep enoughsothe mufflerdoesn't slip on very far, creating a bad seal.No matter how much I torqued them they leaked.
I don't know about this. Mine seemed to slip over the axle pipe at least just as far as the OE mufflers. I'll keep an eye on them.
Old Aug 10, 2008 | 04:19 PM
rlh6805's Avatar
rlh6805
ORIGINAL: tjs2906
Only issue with welding is that if you have them sealed up a full 360 degrees, there is no way you are getting them off unless you go in and cut the pipe. Not so good if you ever want to replace the mufflers or the over the axle pipes.
mtgldr
Feb 3, 2024 09:00 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
TimeLord101
Sep 4, 2015 09:27 AM
