Cast/Camber Plates?
#21
So the best way to go is to just get the plates and screws if I plan on driving the car hard...which I do plan to do occasionally and then get an alignment done after the plates are installed?
#22
Remember either or not both. Get the plates if you are into road racing, etc. If not the bolts will be fine.
#24
The FRPP Springs do not provide an aggressive drop(i.e. sportlines) so the camber will not be off by that much. I installed the H&R Super Sport Springs (1.7"F, 1.9"R) and the camber bolts I bought easily corrected my camber. Another point to consider is that camber bolts are around $30 while the camber/caster plates start at $200.
IMO you will be fine with installing only camber bolts.
#25
Plates are good if you're competing and you intend to either experiment or maintain one set of alignment specs for competition and a different set for daily driving. Mostly a waste of money for "set it to stock and leave it alone".
Norm
Norm
#26
#28
It is a chance the camber bolts can shift and there is also a chance caster/camber plates can bend. Keep in mind the camber bolts are tightened to 148 lb-ft, which is one of the most tourque applied to a bolt in the front suspension. So the chance of it shifting is probably pretty low.
maestro1024
09-21-2015 02:40 PM
