Removed them stupid clips today!!!
FWIW, these aren't anything new. Auto manufacturers have been putting these on cars for as long as I've been working on cars and that goes back to the late 60's.
They really don't serve a purpose except while going down the assembly line so just go ahead and take them off.
If your rims have a depression on the mounting flange where the
clips would be like OEM wheels, the clips are not a problem. If you
aftermarket rims dont have the same depressions, the mounting
flange wont sit flush and the rims will not be running true, hence the
vibrations. It also effects the flatness of your brake rotor as the
tightened lugs will deform the hub and cause the rotor to be deflected.
Also the lugs have a chance of loosening up because of the clips
and the inability of proper torquing of the lug nuts..
jwog666
Dec 27, 2021 08:09 PM
