weird transmission problem
Old Mar 5, 2010 | 12:15 AM
avengence's Avatar
avengence
Mine would move over bumps when the bolts for the shifter came loose. Check the bolts, that could be all it is.
Old Mar 5, 2010 | 10:07 PM
avengence's Avatar
avengence
Did you ever figure out what it was?
Old Mar 6, 2010 | 05:06 PM
PhattyDre16's Avatar
PhattyDre16
In terms of the shifter moving around over road bumps, ya it was loose like u said. I installed Steeda Poly Urethane bushings and it stiffened everything up and now it doesn't move one bit.
But the thing im still worried about is, sometimes, under hard acceleration (which I dont do very often) it will grind in the 1-2 shift. This has happened probly about 8 times. Do you guys think my syncros are F***ed?
Old Mar 6, 2010 | 07:02 PM
str8wick3d's Avatar
str8wick3d
This is acutally common with 2005 models, It probably would have grinded on you instead of your buddy if you were driving. I had this happen to my car to. also a 05, I ended up having to get a new transmission installed to fix the problem... Sorry your having to go threw this but it only gets worse. U can shift into the gear fine under normal driving but any type of "fun" driving you will not shift into the gear smoothly.
Pyrate Dave
Sep 10, 2015 07:30 PM
vintageaion
Sep 8, 2015 10:45 AM
zachary1988
Sep 4, 2015 03:04 PM
