Shifter question!
Shifter question!
Does anyone know what size the metric threads are on the 5 speed stick? I wanna get a Hurst T handle and I need to know this. I find a half inch fine nut spins on but its loose. Does 12 mm sound right?
RE: Shifter question!
Yes, it's 12mm x 1.25 Go to your local Pep Boys, they have a tap & drill bit kit for about $6.00 I have a custom engraved cue ball for my shifter and I drilled & tapped it myself.
Dave...
Dave...
Thanks, '05. I thought someone would know, but now I have a different problem. I took off the stock **** and boot, but damn, the boot is attached to the ****! How would I get it off to reuse with the T handle? Or better yet, does anyone know of a replacement boot that fits the console like stock, but is NOT attached to the shifter handle [****]?
Ok, now I know the **** just kind of rolls off the boot. But that leave a boot with a big hole at the top. Satin, how did you handle your cue ball install so the boot looks right? Cant tell from the pics.
ORIGINAL: Redfire
Dave...
After much carefull consideration, I think I want a T handle that specifically fits the Tri Ax shifter and mates to the factory boot. Ive looked all over the Net and found some that are a kind of weird gold with either a running horse, Bullit, or Mach 1 emblem. And at that, Im not sure if they would fit the tri ax and the stock boot. If anyone knows of a chrome or brushed aluminum T handle that fits the stock boot, Please Let Me Know!
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
treesloth
09-28-2015 07:03 AM
