Weird sequential problem
Old Sep 13, 2008 | 11:10 PM
East87's Avatar
East87
Default Weird sequential problem
Using my remote, i'm able to flash the new sequentials i put in this afternoon. after returning from a drive tonight, i noticed that only 2 of the tail lights on the left side lit when the sequential pattern was activated. i was hasty in diagnosing the problem, simply writing it off as a bad bulb. it seems that the bulb itself works outside of the flashing sequence. if the headlights are turned on, the bulb is dimly lit along with the rest of the tail lights. however, the bulb does not flash in sequence (turn signal, braking, flashers, etc). i can only imagine it's a problem with the harness, but has anyone ever encountered this issue before, and if so, were you able to fix it?
i got my sequentials from AM, so i guess if it's not a simple fix, they'll have to go back, right?
Old Sep 14, 2008 | 12:13 AM
rmssch89's Avatar
rmssch89
I noticed that it seems like the bulb doesn't light up whenever it is required to be bright. Dim lighting still works though according to your description. I would try a new bulb before you go through the hassle of sending the harness back.
Old Sep 14, 2008 | 01:06 AM
East87's Avatar
East87
so it's possible for the filament to be just slightly damaged that it cannot be brightly lit?
Old Sep 14, 2008 | 03:41 AM
So_Cali's Avatar
So_Cali
Mine has the same issue when I lock my car with the remote. Sometimes 2 of the 3 will light up and sometimes all 3 do...I too got the from AM as well. theres no issue when drive with the headlights on so IDK...
Old Sep 14, 2008 | 05:16 AM
Boozshey's Avatar
Boozshey
Change your bulb. Always start at the lowest solution, I am sure it's the problem.
Old Sep 14, 2008 | 08:33 AM
East87's Avatar
East87
so all three sequence when the car is turned on/moving, regardless of whether the headlights are off or on?
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
2015Ecoboost
Sep 17, 2015 01:48 PM
MasterLanMan
Sep 13, 2015 08:21 PM
amandahchase
Sep 3, 2015 10:09 AM
