Need Fuse help
Old Oct 8, 2008 | 07:25 PM
5SPD07GT's Avatar
5SPD07GT
Official Site Sponsor
Default Need Fuse help
Ok i am in the middle of installing my HIDs. I've done this several times before without a hitch. Everything is hooked up right but when i switch on the lights the control module in the hid wiring harness clicks on but the ballasts dont fire up. I am trying to locate the headlight fuse. All i can find is one lableled High beam. Also, my interior dome lights arent working either. What fuse is that? The only fuse boxes are the pass side and engine bay, rite? Any help is appreciated. Thanks
Old Oct 8, 2008 | 07:44 PM
5SPD07GT's Avatar
5SPD07GT
the dome lights work but i still cant find the rite headlight fuse. i have looked in the owners manual.
UPDATE: when i put the stock headlights back in they work.
Old Oct 8, 2008 | 08:38 PM
turbotbirdguy79's Avatar
turbotbirdguy79
Your tapping in to the SJB(smart junction box),dont do that.Instead,tap into the BJB(battery juntion box)under the hood on the passneger side.You may have blown a fuse in the SJB if you have no dome lamps.Do you still have the owneres manual?That will give you the fuse listings.If not let me know,I will look it up for you.
Old Oct 8, 2008 | 08:44 PM
5SPD07GT's Avatar
5SPD07GT
post #2 ... the dome lights work fine and i do have the owners manual. all the fuses are fine. mite be a bad ground? i've tried a couple differant locations with no luck
Old Oct 8, 2008 | 09:10 PM
nmd55's Avatar
nmd55
neither light is working? i had a similar problem this week, but one of the hids was working. it turned out to be a bad wiring harness.
if the normal headlights are working i doubt its a fuse.
Old Oct 9, 2008 | 07:13 AM
5SPD07GT's Avatar
5SPD07GT
they are overniting me a new harness to see if thats the problem
jwog666
Dec 27, 2021 08:09 PM
daytooday
Sep 20, 2015 10:55 AM
wenmill
Sep 11, 2015 07:07 AM
cbird1177711
Sep 2, 2015 04:12 PM
