Broken Spark Plug HELP!! scary pics inside
#21
#22
I'm looking at a bunch of different glues and epoxies. Someone gave me a pretty good idea to use gorilla glue on the broken end of the spark plug, re-insert it into the electrode that's stuck in my engine, let it set overnight and then pull it out. Would anyone else agree with this? It sounds like it would work, but does anyone know which loctite epoxy (or gorilla glue) will bond metal to porcelain?
#23
If I remember correctly there was a guy on here that created his own "custom" tool to remove the lower part of the plug from the head. Anything you can get down there and "hook" onto the shroud should work but be careful with the alum head not to damage it. whatever the cost, you'll rest easier knowing those 2-piece plugs are out of there.
Do you remember how he created his custom tool?
#24
Stangharley - I always forget about photobucket. I just thought that I was not able to post pics due to having limited posts.
#25
#26
NAPA is supposed to have the tool. I changed mine a couple weeks ago. No problem encountered. I used Aerokroil instead of Ford carb cleaner, and the deposits seemed to be disolved. Somehow dripping carb cleaner into a combustion chamber doesn't seem like a good idea to me. I bought the plugs from Summit Racing for $12.95 ea; about $123 total with shipping. I recently bought Champion copper plugs for my 300C Hemi for $1 ea at Pep Boys.
#27
stock autolights or even halo plugs or NGKs with a dab of antiseize will be fine
#28
FWIW, the Autolites are POS just like the Motorcrafts. They are 2-piece design and are causing the problems the OP had. BTW, NKG doesn't even make a plug for the 4.6 05-09 Mustang.
#29
Just so you know, the 05-09 take a new design of spark plug that most manufacturers don't make.
