HELP! Trying to remove wiper arm, won't budge.
I need to remove the wiper arms in order to install the CDC wiper nozzle relocation kit. I mean the whole arm, not just the wiper part.
It says to loosen the nut, then apply pressure on the back of the wiper while tapping the nut. The arm isn't budging. The whole post moves when I try to pull on the wiper arm.
Is there any trick to doing this??
You need to use a small puller like the kind used to pull battery terminals off of the battery post. That's how I removed mine and they 'pop' right off. Use the right tool or you'll bend / break the arms.
