O/R H = < Boost?
So I put an O/R H on last week at the same time as the 10psi pulley. I have been running 8psi up to this point.
I noticed that the 10psi pulley is making about 9.5psi on the car. I was thinking this is probably due to the fact there is less back pressure now.
Has any other boosted member seen this?
Being belt driven doesnt affect the boost pressure in what I am talking about. With a FI car if you reduce restrictions in the intake side or the exhaust side you will see a reduction in boost presure but not in power production. It has basically become more effiecient.
I know when you change to something like LT's you will see a reduction in boost, I was just curious if most have seen an almost 1 psi reduction just by dumping the cats. The car defineatly still pulls. I should be getting a dyno tune this week.
i have LT's, o/r x pipe and muffler deletes. i was still seeing 10-11 psi w/ the 10# pulley. i have since switched to a bigger pulley and am getting 8-9psi. maybe its your environmental conditions.
but i did not test my boost before and after having the exhaust, the exhaust was already in when i got the SC, so i really dont know the before and after effects of having the exhaust, it could possibly be how you say, losing the boost.
Yeah that is how I thought it works. You dont loose any power it just gets more efficient so you can make the same power with less boost.
Thanks,
It sounds like if I ever get LT's with the O/R H I might be able to go to a 3.2" pulley and still only see 10-11psi.
Thanks,
jwog666
Dec 27, 2021 08:09 PM
trashxtrash
Sep 20, 2015 10:49 PM
