HELP, Cross threaded stoptech Bleeder bolt
Old Nov 3, 2008 | 02:14 PM
buffguy's Avatar
buffguy
Originally Posted by Derf00
You can fix your problem one of two ways. 1) use a tap (from a Tap and Die) set to make the hole larger thus allowing a new larger brake bleeder be used. Just be sure to not use the wrong size Tap (tap is the tool that's used, tapping is the process of using the tool to create a new, larger, hole with new threads). You want to make sure the tap you use actually as the same thread as the new bleeder.
2) Self tapping means that the bolt (or bleeder in this case) is specially designed to cut new threads as you twist it in. The nose will be the same size as your existing hole and will have sharp threads to cut. The bolt with then widen like the attached picture. The grooves are to move the metal shavings out of the way so you dont' cross thread while you are tapping new threads.
Thanks for explaining this, I appreciate it very much. Do you recommend any bleeder screw I should use or how I should go about fixing this? Thank you.
Old Nov 3, 2008 | 02:24 PM
RDJ184's Avatar
RDJ184
It comes with a oversize insert.. you have to tap ...not a big deal and it comes with a new bleeder screw 10 minute repair!!!
Old Nov 3, 2008 | 03:39 PM
buffguy's Avatar
buffguy
Cool, do you have a exact part number from Napa? also, do you have a picture of the Tap tool? Would I need to buy the tool separate or is it included in the kit? Thanks.
Old Nov 3, 2008 | 03:56 PM
RDJ184's Avatar
RDJ184
tap is separate if you don't find something by tomorrow my bud will be by from nappa and will get you a part number!!
Old Nov 3, 2008 | 04:02 PM
buffguy's Avatar
buffguy
Thumbs up
Cool thanks, I literally called about 50 different brake shops today asking if they could retap my brake bleeder bolt. All of them were clueless or either just plain off told me to replace the caliper. This forum is awesome, so many members helping other fellow members.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
baddog671
Jul 26, 2016 01:20 PM
Dokilar
15
Oct 16, 2015 08:13 PM
KingRando
Oct 2, 2015 08:06 AM
2poor4u2
Sep 26, 2015 11:08 AM
