Persistent Front Water Leak
Old Nov 13, 2008 | 02:26 PM
kovar's Avatar
kovar
Default Persistent Front Water Leak
My 2007 GT has the persistent form of the front passeger side leak. After 3 trips to the dealership for sealant, weather-stripping, etc, I thought I had it solved until today. Driving through heavy rain, passenger side floor is soaked. Dealer "ran water over windshield for hours" -- no leaks.
I think the leak is coming from under the car or through firewall -- seems only to happen when driving. Have folks experienced a persistent problem that was ultimately solved? If so, how was it solved? I want to go back to the dealer with some specifics if at all possible.
Rains too frequently in VA not to address and there must be a solution. Thank you.
Old Nov 13, 2008 | 02:50 PM
rehtorb's Avatar
rehtorb
I had a similar leak on the drivers side. It only happened while driving, the dealership said water was making its way in through the wheel well. They applied a sealant kit on both sides and i have not had a problem since. Do a search and you should be able to find all the ammo you need on here, make sure you let them know you are aware of the TSB for this
Old Nov 13, 2008 | 02:59 PM
americaniron's Avatar
americaniron
I had a problem with the very same thing a while back, even before the TSB. After the TSB came out the problem was fixed. Three tries in all. Have they used the TSB to work on your problem?
Old Nov 13, 2008 | 03:09 PM
howarmat's Avatar
howarmat
s197 Junkie
Check the spot where your cabin air filter is under the hood. There is a rubber grommet in there that can get plugged and then the water can back up.
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
TfcCDR
Sep 14, 2015 12:08 PM
tramphardrocker
Sep 13, 2015 08:56 PM
MusicCity615
Sep 12, 2015 07:05 AM
