suspension help?
anymore ideas guys? have not had the chance to adjust the pinion angle anymore but i dont really think thats the cause of it.
LCA bushings - OK
panhard bar - have not checked yet
if i slip the clutch alot and have realllllly smooth shifts by feathering the clutch and gas it does NOT clunk... so what is that saying? it feels like something it just catching really hard.
could that have to do with my driveshaft? what about my actual pinion flange... should i replace that? http://www.newtakeoff.com/mustang05-...ionflange.aspx
and guys... by no means do i take it easy on this car, since day one it has seen probably over 1000 burnouts and countless passes at the strip...
LCA bushings - OK
I have a good amount of suspension mods and after installation I noticed the same clunking from the rear of the car when I let off the gas or going over bumps. I checked everything (bushings, jam nuts, torque specs...etc.) and it was still there. Next, I checked my pinion angle and it was set at 3 degrees, which was acceptable. I finally checked the LCAs and the passenger side was about 1/3" longer than the other...WTF. I measured and matched the LCAs and decided to change my pinion angle to 1 degree and double checked all bolts and jam nuts. Since that day, the suspension has been totally quiet
Moral of the story...If you have adjustable LCAs check the length
. Moral of the story...If you have adjustable LCAs check the length
both of them are the same length... atleast on the adjuster area, did you measure the whole LCA or just the threaded adjustment area?
im really hoping its just something that has to do with the pinion angle
Hope it's a easy fix.
