throttle position sensor failed
Old Nov 24, 2008 | 02:38 PM
1morepart's Avatar
1morepart
Default throttle position sensor failed
has anyone with an 08 s197 had this problem???
part number 6l2z9b989c
Old Nov 24, 2008 | 07:02 PM
1morepart's Avatar
1morepart
can anyone chime in and tell me if they had there's replaced before.
(the throttle position sensor)
thanks
jason
Old Nov 24, 2008 | 07:10 PM
pascal's Avatar
pascal
S197 Section Modder-ator
Have you taken off your MAS for cleaning without disconnecting the battery?
If so, that could be the problem because your computer gets a wrong readout.
Try to disconnect that battery for a few minutes and see what happens.
Just a thought...
Old Nov 24, 2008 | 08:16 PM
1morepart's Avatar
1morepart
Just a thought...
i am assuming that you mean the car's battery.....yes, i have disconnected it and reloaded the tune(just in case)...
Old Nov 24, 2008 | 08:29 PM
pascal's Avatar
pascal
I sure miss the oldschool days man...
This over electronized sh#t pisses me off.
I want a distributor and a throttle cable!!
Old Nov 24, 2008 | 08:46 PM
kingsofcrunk's Avatar
kingsofcrunk
Holy crap this seems to be happening more and more and more and more...
Mine is an 06, failed TPS, turns out it was the TB. Hope this helps!
Old Nov 24, 2008 | 08:52 PM
Hufenstang's Avatar
Hufenstang
if it makes you feel any better i have replaced 3 failed TPS on my car since i owned in in january of 05
Old Nov 24, 2008 | 11:14 PM
thedrod's Avatar
thedrod
What are the symptoms? What exactly does the car act like when this happens.
Old Nov 25, 2008 | 01:23 AM
nmd55's Avatar
nmd55
this isnt covered under warranty if u have a CAI right?
Old Nov 25, 2008 | 01:34 AM
kingsofcrunk
Take her back to stock, and wtf would they know? Symptoms = car goes into limp home mode. This mode, I believe, shuts half of the cylinders down, tops the car off at like 45 mph, and sets the rev limiter to like 3-4k rpm. It's meant to prevent more damage to the vehicle, though I believe is very unsafe when it engages at highway speeds.
