throttle position sensor failed
Old Nov 27, 2008 | 02:10 AM
  #21
ohfiveride's Avatar
ohfiveride
i just posted this info the other night.....the tps on the 05's are bad so save yourself the trouble and order the new tps (3rd generation) and install it....the bolts will break off as you attempt to take them out..i had to bring mine to a machine shop and have the broken studs drilled out....your car will stall as you come to a stop (manual) with the clutch in....it rarely throws a code so you'll have no idea like me...didnt throw a code for a month but went into failsafe every time i drove it...then it would drive fine for 2-3 days....the part is about 70
Old Mar 12, 2010 | 11:50 PM
  #22
newjohnre's Avatar
newjohnre
Exclamation 3rd gen?
Is there a part number I should know that is better than the others I am currently about to order 6l2z9b989c form Bob Utter for the same issues. Would I be wrong?
jwog666
Dec 27, 2021 08:09 PM
Dathan
Oct 5, 2015 05:52 AM
UrS4
Oct 3, 2015 06:23 AM
GLOCKer
Sep 28, 2015 07:36 AM
TfcCDR
Sep 14, 2015 12:08 PM
