Wiring a sub and an Amp to stock shaker 500
#21
Hey guys, first things first. I'm VERY NEW to upgrading sound systems and gonna need noob level explaining lol. With that being said I'd appreciate the help !!!
I'm getting things together to upgrade my 05 stangs shaker500 with 2 8" rockford punch he2 subs and a 1200w (V600.2 Vanquish) 2 channel amp. I'm really looking for some info on what type of deck to get and if i'll need to replace the speakers... i really like already having the door subs tho :/
Well please respond with any info i'll need to know about what i already asked and more!.... dont worry i'm dishing out the cash to have it professionally installed lol. THANKS!
#22
Well when i say professional install i mean... not myself or my friend from down the street lol will probably take it somewhere like Circuit city or bestbuy unless thats just plain bad. How does the set up for the subs and amp look? and from experience... should I drop the stock speakers? I know im dropping the deck it skips like a school girl...
#23
#24
Well I already have the subs and AMP got them together NEW for 100bucks its great to know someone who knows someone. I'm trying to stay in the range of another 2-300max on the sound aspect for now. More things im saving up for... intake, grill, ect.
#25
Ok, for that kind of money I would invest all of it into your new head unit since it will be the heart of your system you want the best one you can get. Replacing your other stock speakers you can do down the road. Just find you a good one that has what you want on it. Any shop should be able to install it for you.
#26
So what do you think im looking at? Say 150-200 on the head unit 50ish to install the subs, unit, and amp? Oooooh one more thing im sure ppl have ran into... the trunk... it slides up and the box sizes do fit but not snug on their own. However there is a bar that goes across near the rear speakers do they just put a mount on that to hold it up or would it be better to get separate boxes for each 8ich and put them on the sides of the trunk in the slots?
Oh and ty for the quick replies helps a bunch!
#27
#29
No problem man, that's what these fourms are for, "to help" The amp can go in a number of places depending on how big it is. They may be able to mount it to the under side of your rear deck "if" there is room.
#30
To convert your 5v factory remote out wire to a 12v remote wire, use a standard 12v relay. take the stock 5v wire into pin 86, ground pin 85. put a switched or constant 12v lead onto pin 30, and then run a new wire for the 12v remote line of pin 87 to your amp. Easy low price fix. This also works great for many other applications...
If anyone has questions about this hit me up...
How does the 12V coil of the relay
energize with just 5V from the Shaker?
How about a 5V reed relay from RadioSnack
and do it properly without the worry of
overloading the 5V amp turn on lead since
its just works at logic level currents and
the 12V coil of a lighting relay would be
hard on the 5V amp turn on lead output.
