how to store for winter?
Other than laying a sheet of plastic under the car and lifting the edges so no water flows on top of it and under the car, my only other thought would be to have some air movement beneath (only a little movement is required; not a wind storm) the car IF there was a lot of moisture. The best thing would be some heat (wouldn't take much) with a bit of air movement but that's not always possible.
Yes, the tarp is fine. The intent is to provide a moisture barrier between the tire and the concrete. Over time, the concrete will accelerate dry rot of the tire.
Thanks bro, that was exactly what I was thinking. A fan perhaps? There's a plug inlet off of the concrete pillar on the drivers side. Air movement would definitely alleviate the problem but I wonder if the other tenants (who pay $2700 a month, renting) would be amenable to a fan running constantly for four months under my car on their dime ;-) I'll come up with something, maybe a barrier to keep the water from my friends car from trickling down under mine. Rust hasn't reared it's ugly head yet in the two years I've been storing it this way but I'd like to do anything I can to prevent it obviously. Hoist lifts have shown nothing in the way of any rust but I'm pretty **** about my cars...
Yeah probably not a good idea. I would just lift the edges with bricks at the corners and place another brick on top to hold the plastic barrier in place the whole time. I would suggest 2x4's but it will absorb water and bricks are a better way if you can. Also another idea would be to use the 2x4's on the cement and the tarp lifted on the edges all the way around with bricks holding the raised edges of the tarp on top....hope it helps
One of these may be a viable option for under the car. No noise (like a fan would produce), and cost effective. Having a cover over the car my be an added benefit, as long as the cover breaths. Basically, a heated rod:
http://www.goldenroddehumidifiers.com/introduction.htm
None taken. But I believe it's being stored indoors but where water tracked in from other vehicles also stored there can cause water runoff.
