Help with Drivers window
Old Dec 2, 2008 | 07:01 PM
MD07gtcs's Avatar
MD07gtcs
Default Help with Drivers window
Ok so here is my problem. The auto up feature on my driver’s side window is not working. If I hold the switch it will go up but I have to hold it. My problem is because of this when I open the door the window still drops like it is supposed to but it will not return to the up position. My car is under warranty but just wanted to see if maybe it was something simple to fix on my own like some kind of calibration reset or something?
Old Dec 2, 2008 | 07:04 PM
drfister's Avatar
drfister
Make sure your door is closed and windows in full up position. Hold the window switch in the up position for 2 seconds then release. It should work.
Old Dec 2, 2008 | 07:10 PM
ab's Avatar
ab
^What he said. Did a search on this just last week.
Old Dec 2, 2008 | 07:16 PM
pascal's Avatar
pascal
S197 Section Modder-ator
If not, put both windows all the way down, disconnect the battery for a minute and reconnect.
Crank the car and bring your windows up.
It should reset itself.
Old Dec 2, 2008 | 07:17 PM
drfister's Avatar
drfister
Yea its a common problem. Its happened to me a few times but once you figure it out the first time its all good.
Old Dec 2, 2008 | 07:25 PM
MD07gtcs's Avatar
MD07gtcs
Wow!!! Worked right away. Thanks everyone this forum is great. That saved me from having to go to the dealer and probably 8hrs of waiting.
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
jerrytubes
Oct 23, 2015 12:11 PM
TCStangerv6
Oct 11, 2015 05:57 PM
guitarman376
Sep 30, 2015 05:54 PM
