put in a rear dome light.
I actually really like this LOL it really does suck having to look for things in the dark and not having a light back there doesnt help. Cant wait for the write-up, would you say this is fairly easy for someone that has no Exp. in this kinda stuff?
I'm patiently awaiting the write up because I think this is a fantastic idea! Another perfect example of Mustang owners succeeding where Ford has previously failed!!!
here's the write-up as requested!
ok, here's the write-up.
materials needed; wire cutters/strippers, wire crimpers, flathead screw driver, mechanics wire, 5" L.E.D. strip light.
first, pop off the front dome lamp assembly. it just pulls down from the sides as it is held in by push-clips. be careful not to break it though.
after the front lamp assembly is pulled down, take the push clips out of the back of the headliner to make room to run the wiring under the headliner. you may be able to get away with not taking them out, but my hands are big and i had to.
next, i ran the mechanics wire from the front lamp housing opening to the back of the headliner.
when you get the mechanics wire to come through all the way, (this may take some practice, it tends to get "hung up" on thing up there. thats why i took out the rear headliner push clips) just tape the wires on the L.E.D strip to it and pull it back through to the front lamp housing opening.
the wire that comes with the light strip is about 4 feet long and thats plenty to reach all the way through. i had to trim some.
now mount (stick on) the L.E.D. strip to the top of the back window in the black area. i used denatured alchohol to prep the area so it would stick better. make sure its centered before you stick it on, it's pretty good adhesive.
now its time to make your connections up front. you can see in the pictures that i allready have a couple of things tapped in, so your wiring configuration may look a little different.
i tapped into the drivers side, front dome lamp bulb wires right off the back of the bulb socket.
wire colors for + and - connections are as follows
connect + on led strip (blk/wht wire) to the black wire on the bulb socket.
connect - on led strip (black wire) to the brown wire on the bulb socket.
so for front drivers dome lamp, brown wire is - and black wire is +
make sure you function test it before reassembly of everything.
and your done!!! reinstall the front lamp housing by snapping it back in, reinstall the rear headliner push clips if you took them out, and enjoy it later.
end result =
end result =
What a coincidence...I was cleaning the rear seat area with the car in the garage the other night and wished that there was rear seat lighting. This is a cool mod I'm sure I will do in the future. I'd want something brighter though. I might get two of these straight black modules and mount them a few inches apart in a straight line. I'm also planning to upgrade the front map lights with super bright LED's.
