noise at both wheel wells after 4:10 gear install
i have a high pitch hissing noise from both wheel wells from inside the car, gears have no whine. the dealer that installed gears hears the noise but says no problem found. the noise kicks in after 40mph. noise is not loud but still driving me crazy.
Hissing? that's a sound you dont normally hear. Whine or growl, but hissing is rare.
Perhaps something rubbing against the tire or wheel? Don't know if they loosened the brake lines, but maybe one is rubbing the wheel. Or something brushing up against the driveshaft.
Perhaps check the fluid, too make sure it's not overfilled or undrefilled (remove the plug and if fluid runs out, it's overfilled). Should be at a little below hole-level.
Stange, though. Hissing. Hm.
