Hood adjustment
My '07 will jiggle, even after adjusting the bumper stops but the bumper adjustment DID help a lot. There are rare times it'll do it beginning at 70 or 75 MPH but usually not until about 90 or so. I think the wind speed and direction plays a big role when mine begins shaking.
What is odd is that the left side of the hood is worse than the right side as far as the "dancing" goes. I can reduce the "dancing" by raising the bump stop on the left side, but it does not make it go away. Plus it then raises the hood above the quarter panel and is not aligned properly which drive me crazy too!
So there is no way of lowering the center main hood lock?
Hood pins completely fix this problem?
I just went ahead with the hood pins since the entire front end was diassembled at the time of my conversion.
I adjusted the center lock mechanism down and that helped alot.
Remove the plastic rad cover and their are two bolts that hold lock
mechanisim (8 or 10mm?) 1/4 drive socket works best,
loosen and use wood block w/hammer to drive straight down,
mine moved atleast 1/4", after that redo rubber stop adjustment
to align hood/fender height.
