do these exist? wheels question
Old Dec 15, 2008 | 07:11 PM
pascal's Avatar
pascal
S197 Section Modder-ator
Didn't know 18 came on the CS or if I did, I already forgot...
The wider 18s are out there but it won't be the perfect repro
Old Dec 15, 2008 | 07:15 PM
whtcanbrwnd04u's Avatar
whtcanbrwnd04u
I think they are 18x8.5s. You can put a 275 on there. I had 275/40/20s on my 20x8.5 wheel for around 20k miles. I drive very very aggressively and constantly whip out the rear end and never had any problems...
Old Dec 15, 2008 | 07:34 PM
VistaGT's Avatar
VistaGT
The widest safe recommended size is 255 for an 8" rim. I'm not saying you can't get away with bigger but 255 is the largest "safe" size.
EX: my friend ran 275's on his stock rims and it worked fine----just wouldn't be me
Old Dec 15, 2008 | 07:35 PM
mds08's Avatar
mds08
I looked into this before and the answer is no. Sorry but I have searched everywhere and no luck. If you want to keep those rims then you need to have a section welded in to increase the width. If I remember correctly ifs about $200.00 a wheel not including shipping.
Old Dec 15, 2008 | 08:53 PM
83gtragtop's Avatar
83gtragtop
Originally Posted by Joolander
orly?
whats that, like 10in?
and pascal, by stocker i mean what came on my CS, which are 18s
Well depends how big a sidewall you get.... you could put 275/40/18's on a 8.5" rim. If you have a really small sidewall then it will not "bow" enough to fit a big tire. So a 265/40/18 may not work even though it is small in width.
Here is a spec chart for KDWS's. Shows you what rim width will work with what tire spec.
Also KDW2's.
Also here is a tire size calculator so you can be sure to maintain the same tire diameter.
Brian
Old Dec 15, 2008 | 08:54 PM
83gtragtop's Avatar
83gtragtop
They are an 8.5" rim.
Old Dec 15, 2008 | 08:58 PM
mds08's Avatar
mds08
I had the same polished wheels and now I have the Shelby Torq Thrust in chrome. I then added the tri bar running horse center caps to give it a factory finish.
Old Dec 15, 2008 | 09:26 PM
83gtragtop's Avatar
83gtragtop
Haha thanks for staying on topic....
Old Dec 15, 2008 | 09:31 PM
Joolander's Avatar
Joolander
Lord High Protector
torq thrust would be fine if i could just get them in polished aluminum
Old Dec 15, 2008 | 10:26 PM
Poco's Avatar
Poco
American Racing makes the Torque Thrust D in a polished finish and provide custom offsets for the 05-09' Mustangs.Its a custom order but you have to wait several weeks. Its definately worth the wait.I know they are not Bullitts but they come pretty close.
http://www.americanracing.com/browse_vintage.asp
