Vert top dead
Old Dec 26, 2008 | 03:54 PM
TAMPAGT07's Avatar
TAMPAGT07
Default Vert top dead
After a whopping 2300 miles, my vert top crapped out, luckily it was in the up position. I checked the fuse for ithe top, under the hood and it was fine. I could hear the faint sound of the motor getting power, but the top would not go down. I dropped it offf at the stealership and am awaiting their call. Did any of you vert owners have any problems with your tops?
Old Dec 27, 2008 | 10:01 AM
TAMPAGT07's Avatar
TAMPAGT07
Update: The stealership just called, and the top motor is dead. If I am lucky, I will get it back by New Years Eve. I don't think that I could have used the top more then 20 times in the year and a half that I have had the car. Thank god the car is still under warranty.
Old Dec 27, 2008 | 10:33 AM
Johnboy7701's Avatar
Johnboy7701
Yes and good thing its not your only car... best of luck..
Old Dec 27, 2008 | 12:23 PM
157dB's Avatar
157dB
Cut & Paste Expert
If you wanted to diagnose the problem yourself...
Old Dec 27, 2008 | 03:36 PM
TAMPAGT07's Avatar
TAMPAGT07
"If you wanted to diagnose the problem yourself.."
I knew what the problem was, but I'm not going to fix it if it's under warranty. I told the service manager that the motor was shot. I could hear the motor was getting power, it just wasn't moving the top. I thought he was going to order one on Friday. Now he can't even order it till Monday, then 2 days once they get the motor. I guess they have to take the top out of the car to get to the motor. The worst part is that it's 80 degrees here in Tampa, and I'm off till Thursday, and I have no Vert, just the Caddy.
Old Dec 27, 2008 | 03:41 PM
157dB's Avatar
157dB
Cut & Paste Expert
OUCH
Just posting a link in case someone in the future actually uses the
search function and your post popped up, it would have some sort
of link to help diagnose the problem.
Geeeze, some people.....
Old Dec 27, 2008 | 03:42 PM
awakeinAZ's Avatar
awakeinAZ
This is the first time I have seen a thread about the 05+ having that issue. Most have been about rattles or leaks.
Old Dec 27, 2008 | 03:47 PM
jmk3's Avatar
jmk3
The motor is in the trunk, remove the cardboard floor that covers the spare tire and its right behind the back seat. Look for scuffs on your back bumper from the techs feet when he is in your trunk.
Old Dec 27, 2008 | 03:53 PM
TAMPAGT07's Avatar
TAMPAGT07
"Look for scuffs on your back bumper from the techs feet when he is in your trunk."
The bastards better not leave any scuffs.
"This is the first time I have seen a thread about the 05+ having that issue. Most have been about rattles or leaks."
Me too, I couldn't believe it. I've had several older Vert mustangs, and never had a problem with the top.
lincolnshibuya
Jul 5, 2020 03:05 AM
Thunderball
15
Nov 22, 2015 11:49 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
Bokeo
Oct 10, 2015 08:28 PM
b8checker
Oct 8, 2015 12:55 PM
